4l60e, which cables needed ?
Old Oct 2, 2009 | 04:14 PM
shanekennedy's Avatar
Default 4l60e, which cables needed ?
installing ls1/4l60e in 68 camaro
have the shifter w/ 4th gear conversion
need to order tranny shifter cable
do i need a kickdown cable, or is that electronic now
& what does a throttle valve cable do ?
thanks
Old Oct 3, 2009 | 05:16 AM
poconojoe's Avatar
No you don't need a kick down cable also know as the TV cable. In simple terms, the TV cable in the older non-PWM pressure controlled trannies, controlled the line pressure, which in turn controlled the firmness of the shift. As far as what shift cable you need, I can't help you there, but if you search through some of the swap threads find somebody who did a simulat swap and ask them, if they didn't post the info
