Almost ready to crank for the first time - Quesion
I have almost completed the wiring for my conversion and am preparing to crank it over for the first time. Just a few questions though.
The engine (2000 model) was almost new when I got it (12 mi) but hasn't been run since. Should I remove the spark plugs and squirt some oil on the tops of the pistons? What about the injectors? Should I remove and clean them? Also, should I crank the engine over with the starter and the PCM disconnected until the oil pressure comes up, then connect the PCM and fire it up for real? Anything else I'm missing?
Thanks in advance!
Colin
