78 c10 update
Old Oct 18, 2009 | 01:49 PM
fiano's Avatar
Default 78 c10 update
here is a pic of my 78 C10 nearly ready to fire it up im trying to work out what wires i need for the truck to start i know i need the purple one from the trucks fire wall block but which one for the 12v sw
Attached Thumbnails 78 c10  update-getattachment.jpg   78 c10  update-wiring-20block.jpg
Old Oct 18, 2009 | 02:08 PM
bfrank79's Avatar
this is off the subject but i have a 79 C10, and i was wondering where u got the plastic resevoir for your master cylinder. i cant find one for the 70's models
Old Oct 18, 2009 | 04:04 PM
LS1MCSS's Avatar
For your 12V switched, use the wire that used to go from the firewall to the distributor.
Old Oct 18, 2009 | 06:38 PM
fiano's Avatar
the whole booster is from a 1984
Old Oct 18, 2009 | 06:45 PM
fiano's Avatar
i would but it was a diesel truck so i need to find what goes where
what i really wanna know is where do the thick red wires go??? the purple wire goes to the Starter Solenoid the dark blue and dark green to the oil pressure and water temp and i need a 12v sw
Old Oct 18, 2009 | 06:55 PM
dec010974's Avatar
Default crank it
on my wire harness i have 6 leads from the fuse block. (2) go to the hot sources and (4) go to ignition sources. i connected (2) to batt. and (4) to igniton sources that get power when the key is turn on. also my starter is wired to the old wires that powered the 383 starter. my motor turns over but wil not stay crunk(idle). the company that sold me my harness, computer, tac mod and pedal states that the tac mod is what keeping the motor from running. has anyone encounterd this situation?
