harness question
Old Oct 20, 2009 | 04:01 PM
bigtony08's Avatar
Default harness question
hey guys im building a 91 rx7 with a ls1 from a 99 corvette and am looking for a cheaper route for the wiring harness. so here is my question will the harness from a 5.3 truck work with this engine? thanks
Old Oct 20, 2009 | 05:18 PM
12thstreetjunkman's Avatar
you can use it, you'll have to change the injector plugs, and use the truck pcm. Or swap a few pins around and can use a car pcm.
Old Oct 21, 2009 | 09:45 AM
bigtony08's Avatar
ok can the truck pcm be reflased to run the same way the car does?
Old Oct 21, 2009 | 10:01 AM
mulletnotch's Avatar
Yes. Without swapping any pins around....
The truck harness is what I used on my last project with a truck ECM that had been flashed with an F-body operating system. No real changes need to be made other than cosmetics and injector plugs as others have said.
That and the truck harness leaves your ECM on the drivers side strut tower area unless you unwrap it all and extend.
Old Oct 21, 2009 | 10:04 AM
bigtony08's Avatar
thanks guys you have been a huge help
Old Oct 22, 2009 | 08:54 AM
poconojoe's Avatar
You might also have to change the plugs at the throttle body, since the truck might not be DBW or might use the one plug throttle body
