0 mph VSS - 10 volt DC on output????
Went through great lengths to install a 40 tooth 4L80E reluctor in my Richmond six speed with a VSS sensor so I could get a quality speed signal. Also hoping to use the dbw cruise control.
Okay...on my snap on scanner, I'm reading 0 mph when the wheels are turning.
I jumped into the harness and checked AC volts coming off the trans - I'm getting a stead up and down volt feed as the speed increases/decreases.
However, when I check my OUTPUT (to speedometer) - I'm getting 10 - 11 volts DC.
With the car sitting still and engine off (ignition on) - I'm getting 10.5 volt DC out of the speedometer OUTPUT to gauge.
Sound like a programming glitch or a bad PCM or ????????
I checked the schematic - all wires are in the correct ports.
The VSS outputs the PCM generates for the instrument cluster, etc, are DC square wave. I would expect to see a positive DC voltage there, even sitting still. It would be hard to decipher anything from just a DC volt reading on the VSS output wire.
What kind of air gap do you have between the tip of the speed sensor and the 40 tooth wheel? About .020-.030 should be about right.
where is the 4l80e ring located in the manual trans? I thought the 4L80E sensor ring was about 4-5 inches in diameter, and was pressed onto the rear planet in the 4L80E's.
There is nothing else tagged into the VSS along the way. All the wires ohm out clean.
Sound like a bad program or PCM? If so...any other way I can check that?
