Setting pinion angle.
Old Nov 6, 2009 | 11:38 AM
BlackTA96's Avatar
Default Setting pinion angle.
Alright, so I'm about to fab up my transmission crossmember, but i'm concerned with pinon angle. not sure on where the motor/trans needs be set at(angle). Will I need the drive shaft in in order to figure this out?
You guys get what I'm saying?
Anyway the help is much appreicated.
Old Nov 6, 2009 | 02:36 PM
Buckndol's Avatar
I used a level with a lazer beam. I set the differential to aim just below the tailshaft and set the transmission to aim just above the yoke. There might be a better way but this works for me.
Old Nov 6, 2009 | 08:25 PM
S10xGN's Avatar
Driveshaft not required. You want complimentary angles. For example, if your tailshaft is 3° down, you want the pinion 3° up. That's ASSuming the pinion won't rotate on acceleration or deceleration.
Russ
Old Nov 6, 2009 | 09:18 PM
Pop N Wood's Avatar
You want the two shafts to be parallel. In other words draw a straight line out from each shaft and adjust the mount so the lines are always the same distance apart no matter where you measure them.
i made a couple of laser pointers like in the link below. Mount them to each shaft. I then held a piece of lined notebook paper up to the trans laser pointer and marked how far apart the two dots are both up and down and left and right. I then held the paper in front of the laser pointer at the diff and did the same. Then it was just a matter of adjusting the diff and/or trans until the distances were the same front and back.
http://forums.hybridz.org/showthread.php?t=109413
Old Nov 9, 2009 | 02:39 PM
BlackTA96's Avatar
sound easy enough.
I'll have to try it out.
Old Nov 9, 2009 | 04:44 PM
livefast1's Avatar
i always set mine up with the pinion -2 so i measure at the face of the crank pulley/ dampener and the face of the pinion gear and set it so the pinion gear is 2 degrees less.
engine l \ rear or engine / l rear hope this helps.
Old Nov 9, 2009 | 07:47 PM
CharlieC's Avatar
Great explanation on things here....
http://www.hotrodlane.cc/ONLINETECH/...ineangles.html
Charlie
Old Nov 9, 2009 | 10:00 PM
Mike52's Avatar
Default Pinion Angle
Here is another link with great info on proper pinion angle setting from Inland Empire Driveland. http://www.iedls.com/ptsetup.html
Mike
Old Nov 9, 2009 | 10:11 PM
Petraszewsky's Avatar
There are a lot of variables that play into pinion/driveline angles...You may want to read til your eyes bleed before you take some of this advice into consideration...Although everyone meant well...
