Pass Valve Cover on Driver Side
Old Nov 23, 2009 | 07:54 PM
BBPanel's Avatar
Veteran: Marine Corps
Default Pass Valve Cover on Driver Side
Has anyone tried or know if you put the pass side valve cover (w/oil fill tube) on the drivers side if the drivers coil pack bracket will fit? I guess I'm asking if they are interchangeable. This is a '01 fbody valve cover I'm talking about. I've got an engine I could try it on but right now its kind of buried behind a lot of stuff. Thanks. -Bob
Old Nov 23, 2009 | 08:00 PM
E-Works's Avatar
good question
Old Nov 23, 2009 | 11:54 PM
Pocket's Avatar
Coil brackets use the same PN for both sides so physically they should swap
PCV hookups and being able to fill the oil is another story
Old Nov 24, 2009 | 08:36 AM
gofastwclass's Avatar
Why do this? Wouldn't your brake booster or master cylinder be in the way of filling oil?
