LS3 swap into LS1 CAR.
Old Jun 3, 2010 | 11:57 PM
SMKN LS1's Avatar
I bought a GMPP crate motor (376/480) from Pace (warranty, zero miles, knowing no one messed with it were all benefits.) Scoggin Dickey is also a great choice and I believe they're a sponsor. With shipping included, it cost just under $7K. Expect to spend at least another $1,500 for the TB, conversion parts, harnesses, and miscellaneous. Tuning will likely run another few hundred. But, you can sell a few parts off the crate motor to make up for the things you have to buy.
Old Jun 5, 2010 | 10:16 AM
LE35thSS's Avatar
very nice. can't wait for everything to take flight now...
Old Jun 12, 2010 | 11:39 PM
X-ray's Avatar
Can you give an approximate of the man hours needed for the swap? I'd need to figure in labor to get an estimate of the total for this swap. I figure with the crate motor, extra parts needed, and labor, I'm looking at an easy $10,000.
Old Jun 13, 2010 | 01:01 AM
SMKN LS1's Avatar
It all depends on who does the job. Doing it yourself in a garage with no lift - I'd guess 30 to 40 hours. I took a bit more time for other upgrades and to make it really, really nice.
If it's a professional shop with a lift and all the right tools - a lot less! You should ask a sponsor and see what they say. I'd bet two professionals could finish up in three or four days.
Old Jun 15, 2010 | 12:19 AM
iveseenbetterdayz's Avatar
Default Map
So we can use the LS3 MAP instead of T-ing in a ls1 MAP. Does it work? Because if it does that is the route I am going
Old Jun 15, 2010 | 06:04 PM
SMKN LS1's Avatar
The LS3 MAP works on my setup. I had Straightline tune the car, so maybe you can ask them any detailed questions?
Old Jun 15, 2010 | 08:01 PM
TPI TERROR's Avatar
SMKN LS1
thats some good info!. im looking for your build thread !
Old Jun 16, 2010 | 09:39 AM
JimMueller's Avatar
I bought a Katech MAP extension harness to plug into my LS1 MAP sensor, but we found yesterday that the LS1 MAP sensor is loose in the LS3 MAP hole.
We're trying to bandaid it pending a LS3 MAP sensor, but what's the best solution? LS1 MAP bandaided with a o-ring & bolt/washer? Does the LS3 MAP sensor need any wiring changes to work with the LS1 MAP harness?
Old Jun 16, 2010 | 10:51 PM
SMKN LS1's Avatar
I used Lingenfelter's MAP sensor harness LS1 to LS3 (CE-109103) adaptor.
Sorry, but no build thread for me. I'm having a hard enough time chasing after our two kids and don't have enough energy to type everything up (getting old, I know.) I have 100 or so pictures of the swap, so let me know if you need anything in particular. Thanks!!!
Old Nov 25, 2011 | 03:52 PM
OWENMUSTANG's Avatar
Back from the dead..
Any more installs? How about on a 98 car?
Looks like this is starting to get serious now.
Old Nov 25, 2011 | 04:29 PM
JimMueller's Avatar
Mine's a '98 and I posted a couple of replies up. What do you need to know for a '98?
Old Nov 25, 2011 | 05:03 PM
  #32
What did you do for the fuel rail?
our 98 cars have a return style fuel system, 99 up don't..
I've been told I can't use the rail off of the LS3 to connect to my fuel line.
Old Nov 25, 2011 | 05:12 PM
  #33
JimMueller's Avatar
I have the LS3 fuel rail. Too dark to take pictures tonight, but I can take some tomorrow if you want.
Old Nov 25, 2011 | 07:01 PM
  #34
chuckd71's Avatar
I'm putting a 6.2 where my ls1 was but in a different car. The intake I started with was the return style, but I changed to a returnless and went the corvette filter/ regulator route which seems to be what a lot of people do.
Old Nov 26, 2011 | 07:16 AM
  #35
Cool, sounds good..
What did you do for your fuel system? lines, pump,ect..
would be nice to drive this car again..
Old Nov 26, 2011 | 07:53 AM
  #36
Originally Posted by chuckd71
I'm putting a 6.3 where my ls1 was but in a different car. The intake I started with was the return style, but I changed to a returnless and went the corvette filter/ regulator route which seems to be what a lot of people do.
Please elaborate on what was required to install that..
Old Nov 26, 2011 | 08:23 AM
  #37
JimMueller's Avatar
First, I didn't buy a shortblock or longblock completely assembled. A local guy who is a moderator here had spare LS3 longblock parts from a deal which fell through. So I bought the remainder needed to complete the longblock and he assembled & installed it.
I installed the Racetronix 255LPH & hotwire kits and used LS3 injectors so I could get the correct PCM data. I originally used the FAST pigtail injector adapters, but later switched to the EV1>EV6 enclosed adapters because I thought the former looked sloppy.
Not sure what pics you want, here's a shot from the driver side.
Old Nov 26, 2011 | 09:35 AM
  #38
Did you use the factor return??
unrelated Q's
How does it feel compared to the LS1? More torque, mid range,driveabilty,MPG,ect....
Was it worth the swap? (seems like it 430hp vs 305hp should)
Or would you gone a different way?
Old Nov 26, 2011 | 10:12 AM
  #39
JimMueller's Avatar
Since I didn't install it I don't know. I'm not sure how to physically tell short of asking the builder.
When I first got the car back it was untuned for awhile. But my first impression was that the throttle response wasn't as snappy. Previous motor was a built LS1, roughly 440rwhp 405rwtq. I've never dynoed nor dyno-tuned this motor, just all from logs at this point.
Of course your choice of parts selection will control the performance, drivability, fuel economy, etc. My unmodified MPG went from 11-12 city to 10-11 city (I enjoy driving). The best highway economy I got with the LS3 was 24MPG with 400lbs of equipment in the car; I think I was getting 27'ish in the unloaded LS1. Never tried in the LS3 with the normal 3600lb weight (which includes me).
Worth is subjective as well, depending upon your goals and budget. This is my only vehicle that I had been autocrossing. I built it torquey for autocross & daily driver friendliness. I like the easy 2nd gear starts, I haven't liked the fuel economy since the original motor, but that's another price to pay. I always thought the supercharger route would have been fun, supposedly getting the good balance of fuel economy at low RPM and power at upper RPM.
Old Nov 28, 2011 | 12:40 AM
  #40
pdlightning's Avatar
Default LS1 to LS3
The reluctors go from 24x in the LS1 to 58x for the LS3. That means you should sell me the LS1 harness really cheap!!!
Thanks!!!!!!!!!
