need some injector help
Old Dec 4, 2009 | 02:30 AM
RNation0001's Avatar
Default need some injector help
ok im puttin a 5.3/t56 into a 67 camaro. i bought a ls1 intake and ls6 injectors. so when i get everything together and ready to fire up will the ls6 injectors be too much for the 5.3 to do the first start with? if so how do i get the computer redone for the right injectors and does anyone have any idea how much it will cost? any help is greatly appreciated
Old Dec 4, 2009 | 07:01 AM
FICINJECTORS's Avatar
you are in luck the stock ls6 injector is pn# 0280155931 a grey colored bosch 3. The 5.3 comes with a mini delphi. Both are the same flow rate. 28 at 58psi FP If you need any help call me
Old Dec 4, 2009 | 03:16 PM
really i thought that 5.3 used 24 ls1 used 26 and ls6 used 28? if ur right tho thats great thanx alot
