alternator question
Old Dec 4, 2009 | 08:16 PM
RPD_Vette84's Avatar
Default alternator question
is there a difference between the truck and the car ls1 alternators? is the wiring different from the car and truck?
the reason im askin is cause i have a 02 truck harness and bought a camaro alternator. i believe my harness has 2 wires(grey and brown). anyways i can start the car a couple times and idle it ad itll be fine, if i drive for a while itll be low enough that itll just click. i have a aftermarket voltage gauge and that thing like bounces all over the place when the cars running. im just wondering if i have the wirig different and its not charging my battery. not sure what year car the alternator was off of.
Old Dec 4, 2009 | 10:05 PM
dangerjakeray's Avatar
If the alternator is to blame, when you turn your lights on at night they should vary in brightness( getting dimmer and brighter). Since there is a ticking sound, is the wire on the back of the alternator plugged/screwed in all the way?
Im not sure if the truck alternator is different from the ls1, im wondering the same thing.
Old Dec 4, 2009 | 10:11 PM
yeah when the headlights are on they dim and that. everythings plugged in well. i tugged on the plug and it didnt come out. i think its my battery its just too small for what i have.
Old Dec 4, 2009 | 10:30 PM
Btw, have you dyno'd it?
Id like to see what kinda numbers it made.
Old Dec 5, 2009 | 12:56 PM
Pocket's Avatar
Fbodys use one wire alts, trucks two
Cut the gray wire and tape it back for a fbody alt
Not sure if thats your problem though
Old Dec 5, 2009 | 02:30 PM
think its my battery, i think its too small
its at 12.56ish sitting and 13+ with the car running
no i havent dynoed it i just finished it pretty much and still tryin to get some bugs out.
Old Dec 6, 2009 | 07:46 PM
Afterhours Performan's Avatar
Truck alternators are generally rated for a little more amperage 110, or 130 amp. but are bigger. alternator receives signal{+12v} from computer to excite alternator, if your getting that then a good alternator will put out 13.5-14.9v. sometimes an alternator will put out voltage that is in range, but wil put out little to no amperage {this sounds like your problem} you will need to take it somewhere who has a inductive amp probe and see it the output of your alternator is putting out any amperage {should be 30-100 amps} Hope this helps
