spark plug and altenator wiring ?s
Old Dec 5, 2009 | 09:48 AM
hunterdavidson's Avatar
Default spark plug and altenator wiring ?s
When wiring the altenator you have a red and brown wire on the car. The altenator has a brown and gray wire. this is a malibu 80 and has a 6.0 motor. What spark plugs do you use when yhou run a carberator.
Thanks
Hunter Davidson
Old Dec 5, 2009 | 12:52 PM
Pocket's Avatar
Stock malibu ALT wiring isnt reused
Pin B (red or brown) goes to R15
Pin C (gray) goes to R52
Pins A,D are not used
Old Dec 5, 2009 | 03:13 PM
LS1MCSS's Avatar
He won't have R15 and 52 with a carb.
Old Dec 6, 2009 | 10:08 PM
G-Body's Avatar
sawzall wielding director
Tie the brown wire from the alternator to the brown wire that used to go to the malibu alternator. Now tie the gray wire that is hot with the ignition on (IE the wire that used to power the malibu HEI coil).
