Im cranking but it will not start....
Old Dec 14, 2003 | 12:50 PM
77vetteLS1's Avatar
Default Im cranking but it will not start....
Thanks for all the help guys.. I have it cranking and I have tested for volts while cranking but it will still not start. I have added two more grounds from the frame to the motor and on for the wiring harness to the motor. I have power everywhere except to the coils. While I crank the volts goes down to around 10, is this a lack of ground or is this normal? (10 volts in the wiring harness, while cranking) I haven't been able to contact Dynatech yet to ask them if they eliminated the VATS program or not, I believe that they have, but who knows. Is there a way to test to see without a Code reader? Can anyone think of anything that I am missing?
Old Dec 15, 2003 | 09:07 AM
onehardmaro's Avatar
With out the coils getting power you arent getting any spark. It is not VATS if it is cranking. VATS cuts power from the injectors and starter. I wouldnt worry about the drop in volts. Get power to your coils though.
Old Dec 15, 2003 | 04:46 PM
70 LS1's Avatar
Conversion master
I agree, without VATS, you would not have power to your injectors. But this is not your problem. Sounds like you need to trace the wiring that goes to the coils and look for a ground or disconnected wire.
Old Dec 15, 2003 | 11:17 PM
77vetteLS1's Avatar
I got it guys... It was the damned hookup behind the starter. I figured it was to the EGR.. I will let you know how she is running when I get back.. Again, thank you guys for all the help..
Old Dec 18, 2003 | 07:48 PM
LS1silvy's Avatar
Did it start yet?
Old Dec 19, 2003 | 02:33 PM
77vetteLS1's Avatar
Ya, she's moving. The problem was the hook up behind the starter, I didn't have that hooked up because I assumed that it was to the EGR. I just have a little tuning and I will be good.
Old Dec 19, 2003 | 09:59 PM
cdk4219's Avatar
Yea that's the crank position sensor, no hookey, no startey!
