Kwik Performance alt. mount
Old Dec 10, 2009 | 06:55 PM
LS1LOL's Avatar
Default Kwik Performance alt. mount
http://www.kwikperf.com/lsx_alt_only.html
Will this work in a '96 Firebird? Will only be running stock water pump and alt. No a/c or p/s. Thanks.
Old Dec 13, 2009 | 06:02 PM
Geezer's Garage's Avatar
This kit only works with LS series engines, '97 and later Corvettes, '98 and later F-bodies and '99 and later trucks/SUVs.
Old Dec 13, 2009 | 07:37 PM
spacemanspif's Avatar
Did you mean to ask if that bracket will work on your LS1 that is transplanted into your 1996 firebird? If this is the case, Kwik will most likely be able to answer it for sure but I would think that the bracket will work as long as you have the room on the driver's side of the engine compartment for the alternator to sit. You should have the room, but someone else may be able to give you a much more definite answer.
Old Dec 13, 2009 | 09:35 PM
1994z's Avatar
yes it will work on your ls1 transplant..
