5.3 Swap in 89 Fox
If I buy an a complete engine w/ wiring harness and cpu would I be able to use that in the swap or am I limited to running a carb conversion setup?
I see some of you guys are in process of doing the same thing or have already done it so I have a few other questions that maybe you can help me with or @ least point me in the right direction.
I plan on using the truck motor and just have the stock heads ported and maybe a custom cam since i have seen really good results w/ cam only swaps and ported heads and just some other small bolt ons and maybe throw a nitrous kit on there and spray 150 to it. I know I will need the custom k member and custom headers for the swap as well as a trans mount for the transmission and a custom driveshaft. The trans I was going to use would either be the T350 or T400 since they seem they would be the simpliest for the install and good performance. I will not be driving the car alot and will mostly see car shows/cruises and mostly the race track. Im going to start on the project after the 1st of the year so maybe you guys can help me along. Any help/ideas/changes/info will be greatly appreciated.
If you use a long-tail TH350, the 9"-long version, then you should be able to have the rear yoke from your stock driveshaft fitted to the driveshaft from most any '84-'92 Camaro.
