87 Buick GN
Old Dec 11, 2009 | 01:29 PM
lamdenali's Avatar
Default 87 Buick GN
Guy am doing an 87 Buick GN with an LS1 and 4l60E. I read the S&P article and they said I have to swicth the Body mount around for it to fit. any regal guy out there could help out . GN motor is out and am ready to drop the LS motor in
Old Dec 11, 2009 | 04:54 PM
Monte LS....1's Avatar
Should go right in unless there's something I don't know of. Fit in my g-body and many others just fine.
Old Dec 12, 2009 | 11:44 PM
lamdenali's Avatar
well mine is a V6 to start with . maybe V8 is different mount?
Old Dec 13, 2009 | 12:17 AM
deuce4935's Avatar
you have to reposition the frame mounts to the v8 holes. The GN frame should already have the holes predrilled considering that its a g-body frame.
Old Dec 13, 2009 | 12:29 AM
UR50SLO's Avatar
I think you/original poster ment to say Frame Mount.. not body mount.
But Duce is right .. there are holes in your crossmember for about any motor mount to bolt to.
What are you doing with the GN engine?
I'll take that if you don't want it anymore!
If your not going LS Turbo I don't see the point of you putting a lS in really.
~Scott
Old Dec 13, 2009 | 10:34 PM
lamdenali's Avatar
I sold the motor and Tranny . No turbo on the LS motor for me just NA, I do have more motor and tranny if you interested $2500, LMK
Old Dec 19, 2009 | 08:54 PM
85-6.0-REGAL's Avatar
Any progress? Im very interested in your project since im building a white GN clone out of a 85 Regal Limited. Im about to take the original 3.8 out and get it ready for body work then im Im buying the 6.0 with a 4l80e
Thanks Robert
Old Dec 19, 2009 | 10:42 PM
NemeSS's Avatar
im all for ls swaps. but idk if i would swap one into a real gn
Old Dec 19, 2009 | 10:50 PM
LS1BLKSS's Avatar
Banned Village Idiot
man your messing up the GN!! i'll fucken trade you my SS for it!!
Old Dec 20, 2009 | 02:41 PM
DiabloFormula's Avatar
What are you using for the oil pan?, unless your using the proper mounts the stock f-body pan might not clear, I had to use a CTS-V oil pan in a customers 79 Monte swap, but most all G-body k-members are the same with exception to the I think 83-up are a little differant.........And as far as I know the V6 and V8 mounts are differant and you would need to not only move the mounts up to the V8 spots but also use the V8 style mounts, also PM'ed ya.
Old Dec 20, 2009 | 06:30 PM
gnnova's Avatar
Man do I hate to see a GN get fitted with anything but a GN motor. I've had a 87 GN for years and love it. Good luck on your build.
Old Dec 20, 2009 | 06:33 PM
gnnova's Avatar
Man do I hate to see a GN get fitted with anything but a GN motor. I've had a 87 GN for years and love it. You will have to get SBC motor mounts, the GN motor frame mounts will not work. Good luck on your build.
Old Dec 20, 2009 | 07:12 PM
84BuCkeTOfStEeL's Avatar
I would not recommend using the V-6 Frame mounts. I'm doing a similar swap(84 Regal T-Type) with a 6.0L and I'm using the 200r4 trans to back it up. I was having a hard time with the v-6 mounts, sooo....I went to vato zone and got myself some frame mounts for any v8 80s g body will work. They are part number 2292, about $17 bucks for both mounts. Look them up so you see what they look like. Then I went to flEbay and got some "v8 clam shells" for a Small Block Chevy. These are the upper mounts that would normally bolt up to the engine block itself on the old school sbc they are normally called "upper mounts" or "clam shells", I paid $16 for mine and they came media blasted and painted. The opening on the clam shells must be 4" in order to fit over the motor mount(2292). Is this making sense? I will post pictures later. Then you are going to need some Trans Dapt LS1 swap plates, they are part number 4572, these will bolt up to your new ls1. then bolt up the clam shells to the trans dapt plates and you're done there. You will need to drill new holes for the V8 frame mounts(2292) possibly I'm not sure because I'm not that far into the swap yet, but I may update soon in about a week.
Evedniel
Old Dec 20, 2009 | 07:22 PM
HeadGames Dave's Avatar
Just moved my 43K T-Type the other day to storage and was thinking of the same swap! The buick stuff is just not reliable..and you gotta hate money to do anything. The car went 10's which was maybe part of that parts breakage issue. But, I know if I put the LS with a stock short, TFS heads and the spare 42R I have sitting around I could have some real fun and not break it!
Good luck with your swap..
