Which MSD to use on a carbed 6.0?
Old Dec 12, 2009 | 10:45 PM
Loudpipe's Avatar
Default Which MSD to use on a carbed 6.0?
I just sold my LT1 today and picked up my new 6.0. Im running a carb so my question is which MSD controller do I need to get? I have heard of the one with the "chips" and the other that is PC tunable. I think that the one that is tunable has a part number 6010. The thing is I may have found a used one but it doesnt have a part number one it, it has a place where a "chip" is plugged in that says "curve 1" and on the other end it has a 12-15 pin plug on it. Is that the one I need?
Old Dec 12, 2009 | 11:52 PM
BigDaddyDupree's Avatar
If it has a 24x reluctor wheel then you need a 6010 and i believe that is the LQ4 and LQ9. An LS2 has a 58x reluctor wheel and it needs the MSD 6012. It is the computer programmable one but also comes with chips to kind of base the tune off of.
Old Dec 13, 2009 | 12:44 AM
Paul57's Avatar
What year is your 6.0? '05 (ish) and earlier are 6010...they have a rear (black) crank sensor (24x). The front (grey) sensor is 58x reluctor...MSD 6012
I believe the MSD controller will say "MSD" on it...does it have that, at least? From my understanding you can use both "pills" and laptop, with the MSD. Edelbrock controller is pills only. MSD is the only way to go for an optimum tune.
Old Dec 13, 2009 | 08:57 AM
Loudpipe's Avatar
I think it is a 2002 6.0. The box is a MSD it says that it is a LS timing controller.
Old Dec 13, 2009 | 10:39 AM
holley505's Avatar
24x or 58x look at your crank if you have a 2002 motor for sure it is 24x (count the teeth)
then get the 6LS MSD PN#6010
Old Dec 13, 2009 | 06:51 PM
Dickie-311's Avatar
Originally Posted by Paul57
From my understanding you can use both "pills" and laptop, with the MSD. MSD is the only way to go for an optimum tune.
on the 6010 it is pc tunable and does have pills ....but IF there is a pill installed it over rides the PC tune.
Old Dec 13, 2009 | 06:52 PM
danbap's Avatar
can you use any coil packs with the msd? like truck coils?
Old Dec 13, 2009 | 06:58 PM
Dickie-311's Avatar
yes..
Old Dec 13, 2009 | 07:04 PM
E-Works's Avatar
6010 worked for our ls2 and lq4 engines . they were both 24x . must have been an early 2005 ls2 becuz it came out of a trailblazer ss
Old Dec 13, 2009 | 07:07 PM
danbap's Avatar
Originally Posted by Dickie-311
yes..
thanks.
Old Dec 13, 2009 | 08:00 PM
Loudpipe's Avatar
Yes the engine has a rear (Black) crank sensor above the starter. I guess that means it is a 24X crankshaft.
