Bolting 4l60E to 5.3 Problem
Old Dec 21, 2009 | 08:20 PM
downtowncb's Avatar
Default Bolting 4l60E to 5.3 Problem
Ok, I'm having a hard time bolting the 4l60E to my 5.3. I lined them up on the alignment dowels, and hand tightened the bolts holding the torque converter to the flex plate, I then used the housing bolts to slowly draw the transmission in. I kept turning the assembly by the crank to make sure nothing was binding, but it hits a point where it binds, before the transmission is fully seated. , I went to turn the assembly to torque the torque converter bolts but can't turn it for the life of me.
I realize this is a newb question, but this is one thing I haven't done before, help is appreciated.
Old Dec 21, 2009 | 08:25 PM
xpndbl3's Avatar
torque converter is unseated....pull it back apart and put the converter all the way in, then do the trans housing bolts....and lastly tighten the converter bolts
Old Dec 21, 2009 | 09:16 PM
dfolse62's Avatar
You need to look and be sure you see the two ears the torque conv. slips over. I just rebuilt a pump because someone did what you did and broke the pump innards!
Old Dec 21, 2009 | 11:19 PM
GA95DCMSS's Avatar
Either your torque converter is unseated, or your 5.3 has a dished flexplate. I may be wrong on the flexplate, but def pull the TC out, and reseat it.
