ls based engines in mustang chasis
Old Dec 27, 2009 | 05:14 PM
slolt1's Avatar
Default ls based engines in mustang chasis
i would like to see some engine bay pics of ls based engines in some mustangs i am curntly starting my swap and would just like to get some ideas
thanks
Old Dec 27, 2009 | 05:47 PM
getsum27's Avatar
mine before i got it finished
Old Dec 27, 2009 | 06:10 PM
Jimbo1367's Avatar
getsum27,
lookin mighty good. what are you runing for a trany and radiator?
Old Dec 27, 2009 | 06:55 PM
slolt1's Avatar
yes that looks good how did you do the pedals for the hydrolic system.
Old Dec 27, 2009 | 09:33 PM
knievel's Avatar
2000 GT
6.0
It's farther along now, just haven't taken any pics
Old Dec 27, 2009 | 10:36 PM
jw33's Avatar
LS2 '91 mustang
Stock f-body radiator/fans and a T56 from a GTO
Old Dec 27, 2009 | 11:03 PM
lt4malibu's Avatar
i have since changed the air intake and moved the coolant reservoir but otherwise its the same
Old Dec 28, 2009 | 09:16 PM
getsum27's Avatar
I used a stock 99 camaro radiator and fans and t56 from ls1 camaro
for the pedals.......
i used all my stock foxbody pedals, i took the entire assembly out of the car and cut where the factory clutch quadrant went off of the assembly
i then welded a plate onto the rod that goes across so that when the pedal is depressed there is a pushing motion instead of a pulling motion
then.. a very long story short i used the factory ls1 master cylinder and cut the rod and shortened it then threaded it so that the length can be changed and made a bracket that i welded to the factory pedal assembly and braced it up
Works like a charm! but ill be honest it was a pain and took me a while to get it finished
