6.0L questions
Old Dec 30, 2009 | 11:34 PM
lhkustoms's Avatar
Default 6.0L questions
I Have a 2005 truck 6.0L and am putting it into a 67 chevelle and have a 2005 gto acc. drive and need to put a car intake on it and am curious what intake(s) will work. will a ls1 intake work? thanks
Luke
Old Dec 31, 2009 | 08:02 AM
garys 68's Avatar
I did the same thing in my vette, all LS1 intake/fuel rails work. You'll need to swap the LS1 injectors and the injector plug connector/pigtail. Just tell your tuner what injectors you'll be using.
Old Dec 31, 2009 | 11:30 AM
chevellepowered's Avatar
any intake will bolt up to ur 6.0,, ls2,ls1,ls6,, the new l76,ls3,l92 intake will not bolt up ,,square port heads,, i used truck intake on my 70 chevelle ,had to cut hood a lil bit,but it fit.. and its ugly. ls1 intake is 30 bucks,,used,, id get a ls6 intake if you can afford it.. better flowing.. or carb intake machined for injectors.
Old Jan 4, 2010 | 08:17 PM
lhkustoms's Avatar
Thanks I was thinking that just wanted to make sure before I get one although I just bought a used weiand intake in the for sale section anxious for it to show up
Old Jan 4, 2010 | 09:45 PM
74novacustom's Avatar
Default LS6 Intake
I just bought an LS6 intake with rectangle ports for my 6.0 truck engine. Looks great!!!
