Reverse Lockout
Old Jan 5, 2010 | 12:54 AM
BBPanel's Avatar
Veteran: Marine Corps
Default Reverse Lockout
Working with a harness for a 411 PCM - harness is missing the reverse lock out. What does the PCM do or sense to prevent shifting into reverse? Guess I don't fully understand what the PCM does in this situation. I know many wire it through the brake pedal but do they do away with the PCM trigger and just do a stand-alone wire from a voltage source to the lockout on the trans with a brake switch in between? Thanks. -Bob
Old Jan 5, 2010 | 04:44 AM
rsz288's Avatar
Rev Lock Out occurs above a certain speed. i.e. above 3mph. PCM grounds the RLO solenoid. The other side of the solenoid is connected to 12V supply.
Old Jan 5, 2010 | 12:58 PM
gjohnson's Avatar
Does anyone know if reversing the plug wires on the rev louckout plug will cause any issues? I had to wire in the Revese Lockout plug to my Auto wiring harness and I'm not sure if the wires are reversed. Does it matter?
Old Jan 6, 2010 | 01:42 AM
BBPanel's Avatar
Ok, so for those that wire it through the brake pedal is that done by disabling the PCM control wiring and directly wiring to the solenoid with another power source through the brake switch? Or can one retain the PCM control but run it through a brake switch also?
Old Jan 6, 2010 | 01:43 AM
BBPanel's Avatar
Ok, so for those that wire it through the brake pedal is that done by disabling the PCM control wiring and directly wiring to the solenoid with another power source through the brake switch? Or can one retain the PCM control and also run it through a brake switch?
