Another MLPS switch question
Old Jan 5, 2010 | 04:04 PM
1976CamaroGuy's Avatar
Default Another MLPS switch question
OK, I figured out I had the single plug found on later model 4l60e's. I actually have a single 12 pin plug (and need to get the correct switch now) The wires are as followed:
22 gauge Pink
20 gauge Pink
20 Guage Gray
20 Gauge Lt. Green
22 Gauge White
20 Gauge Black w/ whitestripe
22 Gauge Gray
22 Gauge Yellow
My question is what wires do I need to make sure are hooked up for proper operation? If any?
Old Jan 5, 2010 | 07:14 PM
poconojoe's Avatar
Connector Part Information
15416722 BLK
ASM Conn 12 F GT
Pin
Wire Color
Circuit No.
Function
1
DK GRN
1433
Clutch Start Switch Signal
2-3
Not Used
4
YEL
772
Transmission Range Switch Signal B
5
BLK/WHT
771
Transmission Range Switch Signal A
6
GRY
773
Transmission Range Switch Signal C
7
BLK/WHT
451
Ground
8
WHT
776
Transmission Range Switch Signal P
9
LT GRN
275
Park Neutral Position Switch Signal
10
GRY
1524
Back-Up Lamp Supply Voltage
11
PNK
839
Ignition 1 Voltage
12
PPL
639
Ignition 1 Voltage
Old Jan 5, 2010 | 09:28 PM
Thanks, quick question - which of these wires are relevent to the PCM and operation of my engine and which are relevent to the truck it was installed in and I wouldn't need for my application?
Thanks again
Old Jan 6, 2010 | 04:46 AM
Nevermind, I don't need that plug for my application
