Do I need the stock oil pressure switch for the engine to work?
Old Jan 8, 2010 | 09:50 AM
1976CamaroGuy's Avatar
Default Do I need the stock oil pressure switch for the engine to work?
I cleaned up my harness per Brenden's lt1swap information and noticed I removed the plug for the stock 2004 5.3 oil pressure switch.
Do I need this hooked up for the PCM to fire the injectors?
I am adding the correct switch for my guages in the boss on the side of the oil pan.
Is the stock 5.3 oil pressure switch needed or can I do away with that?
Old Jan 8, 2010 | 10:10 AM
rao's Avatar
rao
The PCM does not need it.
Old Jan 8, 2010 | 11:26 AM
lamdenali's Avatar
I ran my car without it.
Old Jan 8, 2010 | 12:32 PM
gofastwclass's Avatar
The switch is merely an on / off and runs an idiot light on the dash.
