Need Help With Fuel Delivery......
Old Jan 9, 2010 | 06:08 PM
simadownow6988's Avatar
Default Need Help With Fuel Delivery......
Hey Guys,
I have a 05 TJ with a 5.3L/4L60E powertrain.
Upon logging some files with efi live, I have noticed that my fuel delivery is not adequate for the engine. I am currently running the stock TJ in tank fuel pump system. The stock system runs 60 psi (internally regulated), but the flow is not enough.
My question is:
I bought a walbro 255 lph in line fuel pump to fix this problem. I will be running a corvette filter/regulator to send un-needed fuel back to the tank.
Can I run the stock pump still to send pressure to the walbro pump, then the walbro pump increase the pressure to the motor (kinda like a lift pump and primary pump diesel system), or will that not work?
I know I have to drill a hole in the top of the tank for a return line (since the stock system is internally regulated) and i can do the same for a supply line if I cant use the stock pump, but I dont know if the walbro pump will last very long sucking fuel out of the tank. I always heard inline pumps hate the suction part and they dont last long due because of it.
Any help will be much appreciated...
Old Jan 10, 2010 | 08:07 AM
Old Geezer's Avatar
You have correct psi at the rail, but not enuf flow??
What mods are done, that would require more volume?
What's the flow rating/psi on the current pump?
Is the current system a return style setup?
How is EFI indicating U R short on volume?
Adding an external pump, and supplying it w/ one that's of lower volume won't cure your problem..
Adding the Vette reg and leaving the intank reg won't work, either.
Y not replace the internal pump w/ another that has the capacity for sufficient flow??
Old Jan 10, 2010 | 03:01 PM
The pump supplies the proper psi at idle, but not under a load.
The log (done with efi live) shows that fuel delivery is more than 20% low and the motor is running lean.
There is no higher volume drop in replacement pump for the 05-06 Jeep module, only the 97-04 which is way different.
Do I just need to unhook the pump I have now and drill a couple of holes in the tank to put in a supply tube and return tube, and run them to the pump and regulator?
What would you guys do?
