idling rough after a few days...
Old Dec 20, 2003 | 07:24 PM
77vetteLS1's Avatar
Question idling rough after a few days...
Okay, here is the situation. I have been running the engine now for a few days without any problems. This afternoon, when it was running for a while it started idling rough, it didn't stall but it seemed like it wanted too. I have the rear O2 sensors unhooked and the front are hooked into the manifolds. I have the OLD cataltyic converter on there still, but it was running fine up until today. What could my problem be? I don't have the diagnostic tool to check for codes yet. Is there anyway I can troubleshoot this thing? My fuel pressure is good, and I dont think that I have any vacuum leaks, but I am not sure. Any help would be great....
Old Dec 21, 2003 | 08:56 PM
Mark IXZD 150's Avatar
Shouldn't he be running O2 simulators on the rears instead of unhooking them? Unless the PCM has been reprogrammed to eliminate them, the computer is looking for a signal. Can someone confirm this?
Old Dec 22, 2003 | 12:16 PM
Steve1969LS1's Avatar
Mark,
From what I know the rear O2 sensors are not needed at all with the right programming.. the front O2's are what the engine uses for engine management.. the back just check to make sure the cats are doing thier thing and throw an SES if there is a problem.
Old Dec 22, 2003 | 02:42 PM
70 LS1's Avatar
Conversion master
Unhooking the rear O2 sensors will set a code with the PCM, but it will not affect the way the engine runs. I had a problem with rough idle a few days after startup and it ended up being a vacuum line that comes out the back of the intake (not the brake booster).
Old Dec 22, 2003 | 03:32 PM
77vetteLS1's Avatar
The idle starts to get rough when it gets hot. I only have one fan hooked up right now. I am going to go with two 14" fans rather than one 18" fan, hopefully this will get it cooler. As for the vacuum, I check and all looks good back there.
Old Dec 22, 2003 | 04:08 PM
madbrace's Avatar
I had the same problem. I was running open manifolds with the 02s hooked up to the collectors, Bolted up my exhaust just like speartech said and it all went away.
