19166568 pin outs needed
Old Jan 17, 2010 | 04:54 PM
SPG's Avatar
SPG
Default 19166568 pin outs needed
i have one of these controllers for my next project. I could do with a pin out for this as i need to make a few changes.
anyone know how to get a rev signal from this ecu??
Old Jan 17, 2010 | 05:34 PM
LS1MCSS's Avatar
That's an LS2 crate engine controller. What are you trying to do, as far as needing a reverse signal? We need more details.
Old Jan 17, 2010 | 06:06 PM
SPG's Avatar
SPG
thanks, i have an ls2 engine that plan to use this controller with
what i am trying to do is
pick up from the ecu a tacho output (rev counter over here), to go to my tacho
identify what pin 25 on the blue plug is (white wire).
identify 66 on the grey plug (purple/white)
identify 67 on the grey plug '9green/white)
work out if i can use this ecu to output a vss signal to my electronic speedo (have done this with stock gmecu), if so,wha input pins do i need for vss input from trans
can i wire in a mil light to my dash?
can i wire in a low oil light to my dash by taking a wire from the brown ,white oil wire to earth.
i can work most of this out with a pin out, but any help is appreciated
many thanks
