Should I pass on this used 5.3?
Old Jan 17, 2010 | 06:03 PM
billsnogo's Avatar
Default Should I pass on this used 5.3?
I am looking at slowly gathering parts to eventually replace my 454/th350 with a lsx/4l60e.
I found this 5.3 for sale about an hour away, but am wary and need others advice if I should pass.
"1999 5.3 motor/ex manifolds.coil packs,brain,ect. 45,000 miles 1st $500.00 takes it. I have had it sitting on a pallet,
covered with a tarp for a couple of years now. the smog pumps, brain,
fan blade, alternator(still turns over), throttle body(still opens/closes)
etc. are all there."
$500. I am not interested in any kind of rebuild to start, I want to try and start on the cheaper side and then modify as I feel needed.
What say ye?
Attached Thumbnails Should I pass on this used 5.3?-5.3-engine-etc.-003.jpg   Should I pass on this used 5.3?-5.3-engine-etc.-002.jpg   Should I pass on this used 5.3?-5.3-engine-etc.-007-1.jpg
Old Jan 17, 2010 | 06:23 PM
TomM's Avatar
I'd pass Bill, looks in sad shape to me........
PM sent.....
T,
Old Jan 17, 2010 | 06:34 PM
72VenturaII's Avatar
Hey Bill, I'd have to agree with Tom.
billsnogo's Avatar
PM sent.....
T,
Thanks, that is what I was afraid off.
Just needed someone to confirm my gut feeling
ps
Glad to see other x-body friends over here
Old Jan 17, 2010 | 06:47 PM
LS1MCSS's Avatar
It's been sitting outside with some of the exhaust valves open so you know it's going to have some cylinder wall rust on the open ones, even if it was covered.
Old Jan 17, 2010 | 08:13 PM
dec010974's Avatar
Default lsx
i would pass to third that motion. you can find a used lm7(5.3) for $500.00 anywhere. literally. i live in miami, fl and the lq4's and lq9's demand $1000.00 or more. dont even talk about ls1's and ls2's. if you can wait, try to find an lq4. i haVENT driven my 5.3 and i hope it has enough power for my '87 c10. threads on ls1tech say 5.3 are good motors.the are required/wanted especially for there price.
Old Jan 17, 2010 | 08:49 PM
aixgelo78's Avatar
hmmm.... i would rather get get a fresher used motor for that price.....
but the funny thing is, I have had a motor sit outside for a year and a half with a sock on the TB and no cover.... it ran hard and never ate a dime of oil.
Old Jan 18, 2010 | 06:37 AM
TomM's Avatar
Originally Posted by billsnogo
ps
You never know where we'll pop up.........
Welcome to the darkside......
T,
Old Jan 18, 2010 | 10:41 AM
Jeff Smith's Avatar
PM sent.....
T,
What say ye?
Those pixes looks same as I sells those 5.3L. It looks dirty and dust on. Those 3 engines I have selling was wrecked truck. Those motor/trans is in good condition shape.
good luck
check on my sig...
Old Jan 18, 2010 | 12:08 PM
kornerz's Avatar
that 5.3 looks beat....
Old Jan 18, 2010 | 01:15 PM
Pocket's Avatar
good luck
His concern was from the obvious neglect seen in the pictures and from it being under a tarp for several years
As you know tarps disintegrate in the elements, especially after extended periods. With the amount of rust and oxidation covering the engine, its a sure bet its been wet for quite some time
Itd be a great core engine, but not a first choice for a dropout runner
Another vote for pass on the first engine
Old Jan 30, 2010 | 08:48 AM
billsnogo's Avatar
Thanks guys, I passed.
BUT
this popped up
6.0 and 4L80E out of a 2000 3/4 ton 2wd truck comes with harness and computer, motor/tranny works great, about 50K, 2000.00 obo can deliver
If I can get this for $1700-1800, would this be a good or at least decent deal? thanks again
Old Jan 30, 2010 | 09:44 AM
ls1nova71's Avatar
BUT
this popped up
That sounds like a good deal if the miles are accurate. But the 4l80e might be a little harder to get into a Nova though.
Old Jan 30, 2010 | 10:02 AM
TomM's Avatar
Sounds better...be sure to get the accelerator pedal and TAC module....as it should be drive by wire......makes it easier instead of mixing and matching parts.....
T,
Old Jan 30, 2010 | 10:07 AM
ls1nova71's Avatar
A 2000 would be DBC.
Old Jan 30, 2010 | 08:25 PM
alowerlevel's Avatar
And IIRC it will have iron heads on it too, not aluminum
Old Feb 7, 2010 | 09:18 AM
billsnogo's Avatar
Well, the guy does not want to go below 2k, but now have a guy that says he has a 03+ lq9 with 19K on it and is willing to do $800 for the long block.
I also had a guy that came to pick up some parts say he has a rod shop he is moving down to Iowa and has several lsx motors he may sell, one being a 2000 lq4 with 24k on it, but needed to see what it all still had as his stuff is being all shuffled around in the move and needs to get back to me. This one sounds like it will be more complete and he said the guy asking 2k for his setup was high, so I should be able to get this cheaper. He also said he could put different heads on it as they were still the steal heads, and I might be able to work out a deal as he has somewhere an ls6 cam too.... still waiting on pricing though. He also threw out there that he could build an iron ls1 out of a bored out 5.3, fresh longblock for $2500, but that is out of my starting range.
So...... what to do, what to do.....
edit: now he says it came from his personal '05 2500hd, so it would be an lq4, not lq9.......
Old Feb 7, 2010 | 09:40 AM
TomM's Avatar
There is an L33 long block for sale in the classifieds for 800...all aluminum, with 20K supposedly....looks clean, I would buy this if I needed it......there's a picture attached....
T,
https://ls1tech.com/forums/parts-cla...-3-h-o-va.html
