G-Body Malibu Wagon Computer Location?
Old Jan 19, 2010 | 09:32 AM
jeeperanthony's Avatar
Default G-Body Malibu Wagon Computer Location?
Im tryin to wrap up my swap, but I just cant see anywhere to put the ECM in my 82 Wagon. Under the seat seems to be the best spot, I'm just worried about the seat hitting it. Id rather keep it inside if possible to accomodate the cleaner, less cluttered look I have goin on right now.
Old Jan 19, 2010 | 11:02 AM
lamdenali's Avatar
What about the passenger side kick panel like the Grand National
Old Jan 19, 2010 | 02:02 PM
MalibuRacing's Avatar
There are a couple guys on my site that have mounted them under the dash (behind the glovebox area).
I mounted mine on the driver side wheelwell. Now I wish I had taken the time to modify the harness to mount the ECM inside the car for a cleaner look.
Old Jan 19, 2010 | 04:36 PM
I'm 82LSWagon over on MR. Do you know if they are running a/c or not? I looked behind the glove box, there is just not any room that I see.
I have a plan to get it into the kick panel, but it wont be very pretty. Thinkin of goin under the seat again.
Old Jan 19, 2010 | 07:55 PM
Oh, OK. Well I see some of the guys are giving you some suggestions.
Good luck!
Old Jan 20, 2010 | 09:45 AM
gofastwclass's Avatar
I own a G-Body car and I can't imagine how a Gen III computer would fit where the factory computer was without looking like a hatchet job. I've had the entire dash out and unless you remove the AC goods or radio, it isn't going behind the glove box or pretty much anywhere else behind the dash.
I say under the passenger's seat is probably your best option since the engine bay is out.
Old Jan 20, 2010 | 09:39 PM
lsxmalibu's Avatar
malibu wgn....polished the top and mounted it on the front, kinda near the old battery spot
Old Jan 20, 2010 | 10:22 PM
LSXMalibu (or should I say 455_82malibu), what size cowl are you running? What's your hood clearance like? Are you running the truck alternator?
Old Jan 20, 2010 | 11:16 PM
Nice car, really clean!
I like that idea, I may have to use it on something.
Old Jan 21, 2010 | 07:09 AM
lsxmalibu's Avatar
3" cowl, plenty of hood room, could get buy with a 2", the alt is a smaller s-10 unit, 106 amps.
Old Jan 21, 2010 | 10:03 AM
malibu9in's Avatar
I put mine behind the glovebox. It sticks down a little but i hit it with sme black paint and you can't tell.
Old Jan 22, 2010 | 07:35 AM
How? Like the pic above?
I looked in there w/the box out, and couldnt imagine a way to get it in there. Are you running A/C?
Old Jan 22, 2010 | 02:39 PM
2Aspire's Avatar
I don’t know how much seat clearance you have in an 82 wagon but I had the same concerns with my 86 SS Monte with split bench seats. Even with a spot cut through the carpet and padding it will still not be enough.
I also looked to mounting around the glove compartment but the duct work ( I have AC) doesn’t give enough space around that area to consider it.. In the end, I will probably fasten it where the stock monte ECU was and fabricate an enclosure. It will stick out more than the old one but will look fine once I cover it with carpet.
Where did the stock harness and ecu mount in your wagon? Same as mine?
Below is a picture where the stock ecu harness used to come through and where the new harness now is routed. To the right of the hole, on the kick panel is where the stock ECU was...
Old Jan 22, 2010 | 04:36 PM
Yea, the wagon is the same up front at least. I had the ECU under the seat just sitting there, and I will have to re-examine it. Mine is in the stock location now, and I may be able to make it look clean. I'll get pics of the finished when its done, but heres how it is now. I am thinking I can glue another piece to the gap and screw it on the other side. We will see.
Old Jan 22, 2010 | 05:13 PM
Well darn, call me wrong! I have an 83 Monte and I would have sworn the Gen III PCM was too tall to fit there. Did you trim any of the metal behind the panel or was it deep enough without modification?
Old Jan 22, 2010 | 05:47 PM
malibu9in's Avatar
The glovebox is usless now. I cut it up and trimed it flat. I put a metal bar aross the pcm and mounted it to the dash. ill snap a pic
Old Jan 22, 2010 | 05:51 PM
lt4malibu's Avatar
how much dust is on that poor car anyways??
Old Jan 22, 2010 | 06:27 PM
I was rather surprised myself. The metal did not have to be trimmed. The plastic piece on the inside of the ECU however did. And the cover there is actually about 3/4" inward of where it was.(Why that gap was there.) Also, the stock outside piece had to have all the iside parts that held the computer trimmed out. Ill get better pictures when I finish it up, but here is what had to be cut off of the inside piece.
Old Jan 23, 2010 | 01:15 PM
malibu9in's Avatar
you ******! I should have that car running soon. Im waiting on my coil relocators. I had to have them custom made cause im a idiot and didnt measure twice. That bu of yrs is looking right!
Old Jan 23, 2010 | 08:09 PM
2Aspire's Avatar
That really doesnt look bad from the side view.. lol.. Too bad the gap straight on doesn’t cut it.. As you indicated, If you fill that in with the same color trim.. or if its a different color you could shoot it with some color as I have seen some do with trim.. it probably would look pretty decent..
Thanks for the pics..
That’s what I figured.. as useless to some the glove box may be I actually wanted to keep it in tact..
