ls1 t56 in 67 camaro need help !!!!
Old Jan 20, 2010 | 08:26 PM
RNation0001's Avatar
Default ls1 t56 in 67 camaro need help !!!!
putting a 5.3/t56 in a 67 camaro and i ran into a problem. im goin to use the radiator from a 2000 fbody and need to know whats a good way to mount the radiator. i have no idea how to mount it . any suggestions
Old Jan 20, 2010 | 11:14 PM
comeon any ideas or sugguestions on how to mount a radiator
Old Jan 20, 2010 | 11:43 PM
the_merv's Avatar
Veteran: Air Force
I would go with an Aftermarket one..
Old Jan 21, 2010 | 01:10 AM
frito1's Avatar
Check this thread out
https://ls1tech.com/forums/conversio...-camaro-8.html
Old Jan 21, 2010 | 01:59 AM
i looked at it but i dont really understand how they mounted it. do you have to have some kind of rubber dampner or can i just fab up some metal
Old Jan 21, 2010 | 07:54 AM
SUPERBOOST's Avatar
Build you a little crossmember out of 1x2 tubing with flat 1/8or1/4 x2x3 flanges on the end.Make it overall just fit the inside width of your framrails.Use the factory rubber mounts.You will only have to drill one hole for the saddle to pop into and make one hole to fit the round mount into.Clamp it into place and test fit till you get it where you want it with the radiator.Then make a sheet metal plate to hold the rad. at the top simular to factory.When it all fits like you want drill holes in the end flange and tap for 3/8 bolts into the framerails.Simple,works great and is easily removed and installed.
Old Jan 21, 2010 | 07:45 PM
thanks ill have to try something like that
