Oil level sender?
i found a G.M part # 19212593 kit and i have been told by gofastwclass onthis foroum that the oil pan in this kit does not have a provision for the oil level sender on the pan.My question, is this a problem to either not use it will it set a code?When i modify my harness do i even use it.The pan kit is a heck of a lot cheaper then piecing it together.
Any comments help!
Any comments help!
The oil level and oil pressure senders only run a light on the dash and isn't connected to the PCM so no programming is necessary and it won't set a code if removed. I've used the same kit for months without issue and only get the SES light before I start the car like normal.
The price I paid was $150 + tax through my local GMPP dealer.
If you don't have a GMPP dealer locally I've been told the guys at Skoggin Dickey are good to deal with and they are sponsors of the board.
