Engine wiring issue.
Also, if this makes any difference, i am planning on buying a 5 switch toggle panel to run the fuel pump and fan and ignition off of. How should i go about wiring all of these together in the most budget friendly way.
I know i could buy a painless kit but they are $800+ and i can't really afford that. Any help would be appreciated. Thanks!
-Michael
For a DIY, use whatever you can get the cheapest, LS1 Fbody, truck or even cobbled together from JY connectors. Expect it to take 15-20 hours
Several good wiring threads specifically for 3rd gens
http://www.thirdgen.org/techboard/lt...third-gen.html
It's not that im scared of wiring , its just that im new to it and i really am kind of going at it blind. I figured if i could get the ls1 harness and then conform it with the stock camaro one that'd be the easiest way. Thanks for the quick help.
Any other input on the topic would be great.
-Michael
Bob
-Michael
It is unlikely youll find a company to build your harness for more than stand alone. Those require 12v IGN to be hooked up and ran. Gauges are your job
