wiring harness help, power to injector control
Old Jan 31, 2010 | 02:55 PM
eviltwin_1987's Avatar
Default wiring harness help, power to injector control
the new standalone harness for the nova work but then shut off after 20~minutes. I am checking all the grounds, battery supply, and ignition supplies again. There is power to all the injector control pins in the blue ecm connector. I thought that they are all suppose to be grounds? Also there is no pin in blue 75 which i though is an ecm ign wire. any ideas of whats wrong here? Any help would be appreciated.
Old Jan 31, 2010 | 03:28 PM
Pocket's Avatar
Injectors are grounded by the PCM to engage. Be sure you're checking the colored wire for 12v IGN, not the pink one
B75 is OFF/RUN/CRANK voltage and seems to be a truck only option. Most do not reuse this wire
Check the injector circuits. Shutting down a few seconds after starting is a VATS issue. Running for longer than that and suddenly shutting down is a different problem. Any codes?
