4l80E shifter
Old Feb 4, 2010 | 01:13 AM
code4's Avatar
Default 4l80E shifter
Any ideas for a cheap shifter? This is a junk yard build on a 54 chev p/u.
I don't want a column shift as I am using the original steering wheel/column
I have seen the expensive floor shifter but I do not have the room to mount them on the tail shaft due to floor clearance.
I believe i will have to mount some type of cable operated shifter.
Any ideas?
Old Feb 4, 2010 | 08:50 AM
73 nova guy's Avatar
i here the late blazer floor shifter will work the 4l60e is the same i believe. i am using a used B&M pro stick i bought used from Craigslist used and bought a 4 speed gate for it.
Old Feb 4, 2010 | 08:56 AM
slow67's Avatar
Gingervitis Addict
Lokar makes one similar to those but mounts on the floor instead of the tailshaft.
FMS64L80A Floor Mount Automatic Trans Shifter 4L80E 23"
FMS64L80B Floor Mount Automatic Trans Shifter 4L80E 16"
FMS64L80C Floor Mount Automatic Trans Shifter 4L80E 12"
FMS64L80D Floor Mount Automatic Trans Shifter 4L80E 10"
FMS64L80E Floor Mount Automatic Trans Shifter 4L80E 8"
FMS64L80F Floor Mount Automatic Trans Shifter 4L80E 6"
Old Feb 4, 2010 | 11:21 AM
code4's Avatar
Thanks! I found the 10" lokar at summit for 189.00 I will probably go with it.
Old Feb 4, 2010 | 05:48 PM
1tonjeep's Avatar
Default floor shifter
If you have the room, i bouth on for my swap, ended up not using the 4l80 but it is a trans mount style. Ill let it go at a savings if you think you can use it.
Old Feb 4, 2010 | 08:59 PM
726.0chevelle's Avatar
13 Second Truck Club
a standard 700r4 shifter will work on an 80e thats what im using
