MAF troubles Code P0102
Old Feb 6, 2010 | 12:52 PM
xyster's Avatar
Default MAF troubles Code P0102
I have swapped a 2000 LS1 in my Honda S2000 and i am trying to get the emmisions done on it but it is throwing a P0102 code and I cant figure out why. The car runs fine has power and idles good. I did all the wiring myself and have all the orange and pink wires going through a fuse box and everything has 12 volts when key is on and i am getting 12 volts at the MAF sensor but still get code P0102 HELP!!!!!!!!! Not sure if it matters but my reverse lock out doesnt seem to work as sometimes when i go to shift into 5th I will bump reverse. I have had the secondary O2's deleted along with the VATS and skip shift.
