LS3 intake on 243 heads?
Old Feb 8, 2010 | 11:06 PM
battsup's Avatar
Default LS3 intake on 243 heads?
I was wondering if you can run a LS3 intake on a set of ls6 heads. My LH6 requires a 90mm TB to plug into the harness and a crappy LS2 intake costs upwards of 200 on ebay whereas you can buy ls3 intakes with injectors and rails for 300 and from what I read they flow much better. The things I read said that to use LS3 intake you need rectangular heads and not cathedral port, but the LS1 intake I have is rectangular ports as well so i'm a little confused. Will I be able to make this work?
Old Feb 8, 2010 | 11:12 PM
1970camaroRS's Avatar
Bad idea. The ports are so radically different that it wouldn't matter if the LS3 flowed more than the LS2. Just look for a used LS2 and TB from someone moving up to a FAST intake on switching to L92 heads. The LS2 isn't as crappy as you think.
