which fuel pump
Old Feb 11, 2010 | 11:01 AM
ramdaspadhye's Avatar
Default which fuel pump
Aight guys, quick fuel pump question. Which fuel pump do you guys recommend for my carbed application? got an LQ4 with ported 5.3 heads, 223/223 LSK cam... Do you guys think a holley blue would be sufficient or is there another brand you'd recommend more? Let me know what you thinK!
Old Feb 11, 2010 | 11:06 AM
garys 68's Avatar
I've had a lot of success with the Mallory 110s, plenty of volume, no regulator/return needed.
Old Feb 11, 2010 | 01:02 PM
Pop N Wood's Avatar
I had a mallory comp 140 on my 6.0 originally. The georotor sucked up some debris from the tank and was badly scored. I ended up replacing the $250 mallory with an $85 summit rotory vane pump.
The georotor pumps are suppose to be quieter (although mine wasn't), but they don't handle junk as well as the rotory vane.
If you look real close at the pictures of fuel pumps you will see the Holley blue looks exactly like the summit pump. In fact, it looks just like the some of the models from trick fuel and edlebrock. I think these guys all pick up their pumps from the same chinese boat then slap different labels and price tags on them.
I would think anything around 100 GPH should work provided you have good fuel lines and low restriction fittings.
Old Feb 11, 2010 | 03:54 PM
kilrcady's Avatar
had a holley blue pump for 25 years no problems then on replacement had to get new one twice in on season.POS IMHO
Old Feb 11, 2010 | 04:37 PM
Excellent. Thanks for the help! All my fittings will be AN fittings
Old Feb 12, 2010 | 07:17 AM
I don't think I've ever heard anything bad about carter pumps, but they are only 100gph. Do you think I would actually need that additional 10gph from the holley (or equivalent)? Also, has anyone used the edelbrock 1791? It's 120gph with a max pressure of 6.5psi
Old Feb 12, 2010 | 05:04 PM
daschra79's Avatar
I am going to try the Barry Grant 220HR for my carbed 6.0L setup
