What to do with A/C wiring for swap?
Old Feb 11, 2010 | 07:35 PM
Pavetim's Avatar
Default What to do with A/C wiring for swap?
I'm following the harness info on lt1swap for my swap. I have a 98 chevy c1500 and am putting a 04 lq4 in it. I have a harness from a 01 silverado, drive by cable. I'm working on the harness and got most stuff figured out except for the a/c wires since lt1swap takes them out. here is what i got, 3 connectors
1. Black-Ground
Dk Green-A/C low pressure signal switch
2. Black-Ground
Dk Green- A/C compressor clutch solenoid feed
3. Lt Blue- A/C high pressure cutout switch
Dk Green/white- A/C Request signal
Can someone help me out here i'm not sure where they go. I'm planning if possible to use my stock a/c system with a different compressor. Probably a compressor out of the 01 silverado if it will fit. Just not sure where the wires go.
Old Feb 11, 2010 | 07:37 PM
Pocket's Avatar
http://www.thirdgen.org/techboard/lt...ng-i-need.html
Old Jan 8, 2011 | 11:53 AM
1BadAction's Avatar
Pocket, did you ever confirm that the "truck schematic" you posted will work? That is exactly what I did with the harness I'm sorting out right now, but after a second thought on it, I need to know if the computer will provide the ground for the compressor when it sees the +12 at the signal wire, regardless of the low pressure switch input at C2 pin 55.
I wish I would have known about the wideband control using EGR wires before I yanked all those pins.
