Questions about fusing the primary voltage cable
Ideally the big cable from the external relay should be hooked up to bypass the solenoid at the starter. This can be done by either hooking the cable directly to the lug coming out of the starter, or hooking a jumper across the two big lugs on the back of the starter solenoid. Either way effectively bypasses the starter solenoid. Most write ups I have seen just hook the starter solenoid up the normal way, with the exception of running a wire between the battery lug and the S terminal on the starter solenoid.
As for the diode, the primary on the external relay is just a big coil of wire. Cut off power to a coil and it creates a surge of current that needs to be dissipated somewhere. Having a diode across the terminals give the current a low resistance path to be discharged. Without the diode the current has to be dissipated through the wiring. My guess with the relay being all the way in the back of the car there was enough resistance in the long wire that the relay stayed energized for an additional second or two. That is why I suggested the diode to ls1nova.
I would think the remote disconnect switch will provide the same protection against the cable grounding out.
the huge unprotected cable to the starter.
The MAD goy's way of adressing this seems prudent and not all that cumbersome.
The OEM's don't have this added protection typically which is a bit surprising.
