waterpump help.
Old Feb 21, 2010 | 11:48 PM
RNation0001's Avatar
Default waterpump help.
ok a while back i saw a website where you could buy a fbody waterpump with a truck pulley on it. anyone know where i can get one
Old Feb 22, 2010 | 12:25 AM
battsup's Avatar
Not sure about that buy you can buy L92 waterpumps brand new on ebay for $74.99 right now, I just bought one. It'll give you the clearance you're looking for. Do a search on "l92 water pump"
Old Feb 22, 2010 | 12:50 AM
355TurboLT1's Avatar
Is the L92 pump interchangable with earlier motors(ie 5.3 6.0). I have a Lq9 03 and am curious about the water pump. I need a new one and wonder if a L92 is the same or different. Thanks
Old Feb 22, 2010 | 02:00 AM
poweredbychevy's Avatar
The L92 pump will work for you...
Old Feb 22, 2010 | 04:43 AM
garys 68's Avatar
I just swapped the pulley from the truck pump myself. If you're looking for one to use truck spacing with an LS1 intake and DBW, I'm not sure if the L92 will clear the DBW motor. Another option may be the 2010 camaro L99 (VVT) water pump. It has what looks to be truck spacing with the water outlet on the drivers side front.
