5.3 maf wiring
IAT Hi/Lo are PCM controlled, as well as MAF signal
MAF 12v is usually shared with the PCM IGN fuse
MAF grd can be grounded anywhere
25 TAN 1671 HO2S Low Signal - Bank 2 Sensor 2
26 TAN 1667 HO2S Low Signal - Bank 2 Sensor 1
3 TAN 1465 Fuel Pump Relay Control - Secondary (Dual Tanks)
25 TAN 472 IAT Sensor Signal
are 1671 and 1667 some kind of sensors? what do they look like?
I'm in a similar situation to the one you were in. I have a MAF, but no pigtail for it and I need to figure out where to wire it into the wiring harness. I can probably figure out the wiring from this thread and some other pinout data I've seen, but I still need a MAF pigtail. Where did you buy yours from and how much did it cost you?
