Lq4 into 98 z28
If you can link me to a thread that answers these questions I'd appreciate it. If I need to post in a different section just let me know.
The only thing to look out for if it's an earlier LQ4..the Crank may be the longer version. If it's not just remove the Spacer if if has it. If it is, then you won't be able to use that Crank unless you install a 4L80E.
Also some of the earlier Block had a Casting Lug in the way that won't allow you to use a Car Starter.
