4l60 trans wiring?
Old Mar 6, 2010 | 10:18 AM
brad22486's Avatar
Default 4l60 trans wiring?
cant figure out wiring for my transmission. can someone tell me what wires go to what pin. its for a 98 camaro harness. any help is appreciated thanks
Old Mar 6, 2010 | 08:40 PM
aknovaman's Avatar
https://ls1tech.com/forums/attachmen...-98-wiring.doc
Old Mar 7, 2010 | 07:34 AM
brad22486's Avatar
im lost which one is for transmission. im being dumbfounded by this transmission wiring
Old Mar 7, 2010 | 08:51 AM
aknovaman's Avatar
Go here and scroll half way down to see the 98 schematics, not the pinouts. It's the actual schematics with PCM pin #'s and trans connector letter you need.
http://chevythunder.com/
Old Mar 7, 2010 | 11:58 AM
topspeed7's Avatar
98 trans am
here is my diagram that i have used over the years i know there are some wires that have the same color but the go to different connectors in the ecm
for example there are two yellow with black stripe and two pink. need to be carefull because one pink is 12v and the other is signal, the yellow with black stripe, one is fluid temp and the other is2-3 shift solenoid signal. ill try to post the connector pin out later.
File Type: bmp
Old Mar 7, 2010 | 02:36 PM
topspeed7's Avatar
here is the plug pinout numbers are matched to the first post i made.
if you cant open the files pm me and i will email the pics
File Type: bmp
Old Mar 8, 2010 | 07:28 AM
brad22486's Avatar
thanks
