engine problems helpppp
Old Mar 6, 2010 | 06:03 PM
RNation0001's Avatar
Default engine problems helpppp
ok started up my 67 camaro with 5.3 and at first it idles highabout 3k then goes down to like 500 so i shut it off. tried again and it idled to about 3k then went steady at around 900 kinda choppy. i figure most of all that is caused by not doing a idle learn. but my real problem is when i hit the gas it cuts out and wants to die until i let off then it goes back to idling. anyone knoow y? im going to get a scanner today any suggestions?
Old Mar 6, 2010 | 07:19 PM
pdsq98gt's Avatar
Hook up that scanner. Is this a fresh swap, or did it run fine before?
Old Mar 6, 2010 | 07:46 PM
Fresh swap.
Old Mar 8, 2010 | 07:50 PM
JAY ROD's Avatar
Vaccuum leak,or low fuel pressure.
