crank voltage what's that?
Old Mar 12, 2010 | 11:33 AM
gazgab's Avatar
Default crank voltage what's that?
Hello,
In my harness (LQ4 2004 express drive by cable), there are pinout 59green a crank voltage wiring: what is that?
Thank's
Old Mar 12, 2010 | 11:46 AM
flame's Avatar
If you are going to use the pcm to control the starter relay then you need that wire hooked to B+ in crank position only and pin 39 on the other pcm plug triggers the relay. If you are going to control the starter without pcm then you don't need it.
Old Mar 13, 2010 | 04:10 PM
gazgab's Avatar
Thank's
