map sensor help needed
Old Mar 20, 2010 | 02:06 PM
RPD_Vette84's Avatar
Default map sensor help needed
i bought an after market 2bar map sensor and need to splice the wiring into the plug that was supplied.
my harness is a 02 5.3l and the wires goin into the map are (lt green, grey, and orange and black). i need to know which ones go to the new wiring
wiring on the new sensor is.
red needs +5v
white needs signal
black needs ground
can anyone tell me which ones go the the factory harness?
Old Mar 20, 2010 | 02:42 PM
forcd ind's Avatar
an older chart shows gray- 5v, light green-signal, and orange/black-gnd
prob has not changed, but maybe someone else will chime in
Old Mar 20, 2010 | 02:44 PM
thanx. ill wait and see if someone will confirm that.
i was tryin to use this but got confused on some of it.
https://ls1tech.com/forums/conversio...rams-here.html
Old Mar 20, 2010 | 03:19 PM
Pocket's Avatar
Colors are correct
Some MAP sensors use a different color low reference. Blk, ppl, orn/blk are the most common
