ls1 conversion columbus ohio
Old Mar 28, 2010 | 08:31 PM
brad22486's Avatar
Default ls1 conversion columbus ohio
has anyone in or around columbus ohio done the ls1 swap and or converted their own harness that i can either come look or they come to me to show me how to finish this thing up its getting irritating.
Old Mar 28, 2010 | 09:35 PM
Pocket's Avatar
Lots of wiring info here
http://www.thirdgen.org/techboard/po...009-post4.html
Got a specific question?
Old Mar 28, 2010 | 09:42 PM
Rick Speed's Avatar
I'm doing one right now.. what exactly do you have problems with?
Old Mar 28, 2010 | 10:07 PM
fptransport's Avatar
are you tring to use the original fuse box? or make it into a stand alone?
either way its easy,, but it might help if you tell us what year model eng/ecm you are using ,, also what tranny 700r,4l60e 4l80e?
Old Mar 28, 2010 | 10:22 PM
grif54's Avatar
I've done a couple of these swaps on different cars. What are you doing this swap in? I could help you out if you need it and I live in Columbus. If you PM me I will give you my number if you want. I'll try to help as much as I can.
Old Mar 29, 2010 | 06:53 AM
brad22486's Avatar
im having problems finishing out the harness. and i have a 98 z28 ls1 4l60 im putting in a 79 camaro
Old Mar 29, 2010 | 08:46 AM
Pocket's Avatar
What problems are you having? Older cars are pretty simple to wire in. The harness must become a full stand alone unit including an IGN relay to drive the fuseblock. Your only connections are for the electric gauges and the IGN switch(old coil 12v). Your cable speedo will require a driver box as the 4L60E cannot directly run a cable. Cable-x is the easiest to install with 3 wires to hookup: 12v IGN, grd and speedo output from the PCM
Old Mar 29, 2010 | 01:24 PM
Rick Speed's Avatar
http://www.lt1swap.com/ls1_wiring_ha...connectors.htm
all the info you need to make it stand alone
Old Sep 28, 2020 | 10:39 PM
Ioannisnikiashalkias's Avatar
Default My friend lives in Columbus he wants an LS swap what your number
how can I get a hold of you for an LS swap?? My number is 6142842560
Old Sep 29, 2020 | 12:11 AM
You might not. He hasn't been here for almost 3 years
Old Sep 29, 2020 | 12:36 AM
SwapStang's Avatar
Originally Posted by G Atsma
You might not. He hasn't been here for almost 3 years.
Wow.... do people check dates anymore? 10 year old thread!
Old Sep 29, 2020 | 10:24 AM
I don't think any ever do. This happens way too often.
