Hurst Hairy project, need thoughts
Old Apr 3, 2010 | 10:37 AM
66Olds's Avatar
Default Hurst Hairy project, need thoughts
Hello, I am new to this forum, but would like your guy's opinion on an idea I had for what to do with my 1966 Oldsmobile. The original Hurst Hairy was a 66 Olds that was powered by two toronado V8's. I think it would be awesome to create a new, modern interpretation of this car. My idea is to stick two ls7's in, each fitted with the carburetor intake, and capable of between 500-650 hp. The front engine would most likely have to be in the transverse position. Heres my question, is there a manual fwd transmission that can stand up to this kind of power? Also, would it be better to mount the rear engine transverse as well, or go with a transaxle. I would like to be able to have it be a stick shift, but can settle a sequential paddle shift if necessary. Anyway, I'd like to hear your thoughts on this.
Old Apr 3, 2010 | 10:49 AM
Jimbo1367's Avatar
welcome. Sounds interesting. And pricey. T-W-O $14,000 engine. YIKES lol
iF YOU GO THROUGH WITH IT. tAKE A LOT OF PICS AND SHARE.. I am proud to be a pic *****. LOL
Old Apr 3, 2010 | 08:26 PM
Pocket's Avatar
Strongest FWD manual trans GM has is the G6 6 speed. Fiero guys love em, but they still snap easily at the power level you're talking
A Porsche transaxle can handle a good bit of abuse, but is longitudinal and would push the engine father forward. not sure if it will still fit your chassis
You may have to have a pair of custom trannys built. Expect some serious investment in any direction you take, just getting a pair of LS7s in one vehicle and to not rip it apart
Old Apr 4, 2010 | 04:34 AM
1dirtyZ's Avatar
why not the use the same trannies that were on the car ( th-400 off a front wheel drive GM car - caddy i think) they should handle the power.
Old Apr 4, 2010 | 02:19 PM
mpmjason's Avatar
might have to consider less power. Possibly look at the fwd V8 cars (monte SS, GP GXP, Imp SS) drivetrains. Having two 300-400hp engines is still a good bit of power, and i imagine alot cheaper than going the LS7 route
Old Apr 4, 2010 | 03:41 PM
Gordo78's Avatar
Awesome pic of the original.
Dude awesome if you can pull it off. But it will take A LOT of work and money.
