chevelle hood clearance
I saw one guy cut the support brace out a bit just to get clearance.
http://www.summitracing.com/parts/MOR-65920/
i'm also using an sv1 carburetor. with the air cleaner lid off i can shut the hood and it crunches the air cleaner a little bit. it's about 1/4 inch too high. with the air cleaner lid on it is so much worse. my hood closes but the back sticks up.
My question is: my car is a 1968 chevelle, originally came with a 327 so it has those lower engine mounts and i am using energy suspension poly upper mounts. did you guys need to turn your lower engine mounts around? i feel like my engine should be moved back and down a tad.
http://www.summitracing.com/parts/PRO-66808/
i'm already using a 1 3/4 inch drop base. can't go anymore than that.
no cowl hood i want the car to look stock.
