temp sender sits back in the adaptor
http://www.summitracing.com/parts/ATM-2277/
the through hole was too small so I had to drill it out some, now the sender fits in but it sits a little over a 1/4" back when when tightened. pic bellow
will this give accurate readings even though the tip of the sender will not be directly in the waster stream? what have other done with this adapter?
), is this what every one uses?
