LS Mounts for 70-81 camaro
Old Apr 8, 2010 | 05:47 PM
chriss71z28's Avatar
Default LS Mounts for 70-81 camaro
I have a set of the good energy suspension small block motor mounts for my 71 camaro. Can i use these along with the adapter plates from transdapt to mount a 6.0L in my car? I was also thinking of using a 700r4 trans with this. That should mount right up to the 6.0 if i get that gm performance adapter? From what i have been reading, the 98-02 fbody oil pan should be the best to use in my body. I am not going to be running a/c, so should i also get the idler and serp belt pulleys from a non-ac 98-02 fbody also? Thanks for the info
