crank angle relearn, with out break 5v wire
Old Apr 9, 2010 | 08:19 PM
awd-rwd racer's Avatar
Default crank angle relearn, with out break 5v wire
i have a ls1 in a rx7, i have no 5v brake signal wire. how do i do a crank angle relearn if i have no 5v signal that shows the pcm im holding the brake down?
Old Apr 17, 2010 | 04:36 PM
anyone?
Old Apr 17, 2010 | 08:39 PM
Pocket's Avatar
Add the wire
Old Apr 18, 2010 | 08:18 AM
Originally Posted by Pocket
Add the wire
but what would i hook it up to? i dont have a gm car.
Old Apr 18, 2010 | 08:55 AM
Pocket's Avatar
Brake switch. Tail light switch if you have to. Not being GM doesnt mean it doesnt have a brake switch
The pin needs 12v IGN until the brake is depressed then its open. Standard N/C circuit
Old Apr 18, 2010 | 09:07 AM
rotor vs. piston's Avatar
Is this a normal issue, I thought it just took a few cranks for it to relearn. The times I started my engine after I've let the computer sit w/o power connected, cranked over a few seconds, doesn't start. Cycle ignition, starts right up every other time.
Old Apr 18, 2010 | 02:34 PM
Palomba's Avatar
You run a relay off of the break switch. So that it is 5 volts always until the break switch signals the relay to open.
Old Apr 24, 2010 | 06:59 AM
DeanJ's Avatar
Which pin # on the PCM would this be, 2000 Camaro, 6 speed, PCM ?
Old Apr 24, 2010 | 08:36 AM
Pocket's Avatar
B33
Pin is the same for 99-02
Old Apr 24, 2010 | 10:41 AM
DeanJ's Avatar
Pocket, you are the man. Thanks a bunch!! I didn't have this circuit wired to start with ( T56 trans) but I'm going to add. I see you're in N.C., what town? Later, Dean.
Old Apr 24, 2010 | 09:33 PM
Pocket's Avatar
Near Winston
Drop by and check out my 3rd gen swap
